BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
My current water heater was manufactured in March 1990... yes it just turned 29 years old. So it is time for a new one. Should I go tankless?
Do you have gas or electric? Do you have kids and do boatloads of laundry? Lots of simultaneous showering? What is your overall demand for hot water?
High demand for water. At least two showers each morning, that will be increasing very soon as I have three kids approaching morning showing ages. With those three kids is a lot of laundry as well. Simultaneous showering will be a must in a few years.
He hasn't stated the problem yet.So, if it suits your needs better, spend the money and make it happen.
But do you have natural gas? Do you have well water or city?
A 50 gallon natural gas water heater will provide something like 90 gallons of water in the first hour, assuming a 120F setpoint. If you up the setpoint, you should be able to get 150 gallons out of it. A great gas water heater costs half of what a tankless does, and costs the same to operate.
I figured he knew what the problem is and what his needs are. Probably no reason to not buy one if it suits his needs.
I'm not sure where your head is at, sounds pretty clear cut.
Well, tankless units have a high upfront cost, not-insignificant yearly maintenance, and you have to size the unit based on an 85F temperature delta at 3.5gpm (city water in the winter).
Tank units cost a lot less, can provide a ton of water to multiple fixtures simultaneously (I did some quick math and estimated two showers simultaneously for 52 minutes cont), and a similar lifespan as a tankless.
Depending on if you have natural gas, a well, and are looking for a lot of simultaneous fixture use or sporadic use throughout the day, the math changes significantly.
And we haven't even talked about venting....
It will be more expensive to retrofit to a tankless than just to replace the existing tanked with another tanked unit (especially if your existing unit is electric), and you're probably not ever going to save enough energy to recoup costs to offset it.
5.5 yrs on a Rinnai running natural gas. Zero complaints. I would do it again.
You just spec the unit for your demand. I got the next to largest unit navien makes. Why? Because for $50 extra why not?Can two showers run at the same time and have enough hot water?
This has been our experience. We have NG and we keep the setpoint up at "A" or whatever 1 over the recommended "safe" level is - it's pretty damn hot, enough that on full on pure hot it is steaming. We have a standard 40 gal tank and I cannot remember ever running out of hot water, even after 3 showers in a row, with one of them being our teenage son who stays in there for what seems like an eternity.If you up the setpoint, you should be able to get 150 gallons out of it. A great gas water heater costs half of what a tankless does, and costs the same to operate.
