chromerunner
The Scrambler
- Jun 18, 2006
- Biscoe NC
You cannot build a cherokee, the unibody will fold like a taco and turn into a super-massive black hole the moment you slip a tire. Any money you throw from that point on will end up in oblivion.
(Implied Sarcasm)
If you want cheap and reliable, the only vehicle you can possibly squeeze into a sentence using those two words is "toyota".
I've built a cherokee, and while my application may be more than you're talking about, I can vouch for them being super expensive. A straight axle toyota is much cheaper than an XJ and more reliable (Even if you buy ifs and convert). I've seen stock birfields (with drivers that aren't idiots) handle tire sizes that the puny d-30/8.25/35 combo, bottom-line, can't. 35's and stock shafts is do-able, whereas on the Jeep, I wouldn't dare. Plus....swapping in longfields is cheaper than a full blown axle swap - ask me, I know (as upgrading a 30 is probably not a "reliable" choice).
From the XJ side, if the biggest tire you're wanting to try on a dana 30/chryco 8.25 combo is a 31, then lock it and wheel it (you are looking at lift prices here, the toy requires no lift for this size, or maybe even 33's with a bit-o-trimming). If you go any bigger, say a 33, you'll probably be okay with a super light foot. Any thing bigger, both axles aren't going to make it long (maybe to the first turn in the trail). Take into account however that with a 33 and bigger, you're looking at really getting into money with the required amount of lift: SYE (MUST), driveshaft, adj. trackbar, control arms, etc.
---A Toyota on 33's is good to go, as would probably be 35's on a light foot (locked).---
Just my opinion and experience.
not to start a pissing match but to say a toyota can be built cheaper than a cherokee deserves a E-slap....
Ive done both and tried both systems. Ok D30 is no match to the toyota front but i can buy a decent cherokee for $500.00 all day long....I cant touch a running driving toyota with solid axle for under 1300.00 By the time you lift the yota...Buy tires and do a dual or geared case to have any crawling power i could build a capable and nice cherokke that i could wheel most places have fun and drop off my buddies when im headed home from a day of wheeling..
Im not hating on toys...i have one in the shop now im building (theres also a cherokee beside it) but when your talking cheap and reliable....the cherokee is a hard one to beat.If i was in your shoes (op) i would look for a already built truck to stay cheap. (pm if intrested in a cherokee, i can find you a nice one for 3k and under)
