- Apr 18, 2005
- Greensboro, NC
^ Good take and info!
Yea, they killed the jeep and couldn't kill the yota. There's your answer.
I'll sell you a 78 complete for a grand.well, a full size bronco is out of the picture unless your talking 78-79. the TTB can get a little expensive for you and sometimes be a pain. Bronco II will just wear you down in broken parts and rebuilt transmissions. not to mention the 7.5" rear axle and dana 28 front ttb.
im a ford guy. i love broncos. but, if i were just beginning, i would go with a XJ. no need to explain why...see above.
I would look for a 90 or newer XJ. 88 and 89 where the first years with the 4.0 and can have some funky electrical problems due to the type fuel injection system they have.
I would say save a few extra pennies and buy something built and done....xj, toyota, or sammi.
or just buy an xj and wheel it!toyota all the way. find some chevy springs in the junkyard to put in the rear, put the rear yota springs up front, buy some used geared third members and weld the rear. then all you need is a used set of 35s or so and your good to go. will cost way less than lifting and gearing an xj.
And then break the axles and then replace them with stuff that won't break under 31" tires and then replace the aluminum t case cause you cracked it in half, etc etc. Buy a stock solid axle yota and wheel it. You won't have to worry about breaking the axles, or the t case or the engine. And when the money comes in for parts, you won't have to replace 90% of the drivetrain to keep it from breaking with bigger tires/lockers.or just buy an xj and wheel it!![]()
When you want ot lift the yota, it's $50 for chevy springs and the cost of tires. Lift an jeep. Much more than $50. The thing about a jeep is by the time you're done with it, it isn't a jeep anymore. The only thing jeep left is the body and vin number.![]()
No necessarly. I have seen xj's with little to no lift run 35's and not break. I have also seen them break with 31's. Same for yotas. I have seen them both broken with small tires and big tires. Best part of an xj is you can actually get more then you and your gear in it. Try to take your other half and or kids and gear in a truggy for an extended trip. Not happening.And then break the axles and then replace them with stuff that won't break under 31" tires and then replace the aluminum t case cause you cracked it in half, etc etc. Buy a stock solid axle yota and wheel it. You won't have to worry about breaking the axles, or the t case or the engine. And when the money comes in for parts, you won't have to replace 90% of the drivetrain to keep it from breaking with bigger tires/lockers.
LOL! Good point!True. But thats what 4 Runnas are for!
