murphystoys
- Oct 6, 2005
- Greensboro NC
Ive got an 88 wrangler 6 cyl. that everytime I come to a stop it cuts off. Does anyone know or ever had this problem?
press in clutch before you come to said stop
32/36 DGEVcan you tell me witch weber carb you went with?
That is correct, & remember by the time you get one from a junkyard rebuild it, do the install & get it set up right, you'll have only spent about $100.00 - $120.00. You'll also have a very good understanding of how it works. If you buy one already done, you lose that valuable knowledge, & spend more $$$Im trying to get my carb and if I understand corectly the only carb thats not gonna give me trouble is the 2100 with 1.08 right? Ive seen guys on here talkin bout 1.24 and others that r givin them problems.
From what I've heard, they work well. Some folks have some problems with them once in a while, but if set up properly they do work well. That said, Forget about the weber & re- read my last post, & the one before it. This took me A week to get the carb, get it all done & all the details worked out. The actual rebuild, not counting the overnight stay in the dunk bucket took 2 hours altogether. I was being meticulous & extra careful about each step though. Think of how impressed your friends will be, when you tell 'em you did that. You weren't taking no for an answer. You were gonna make that heep work if it was the last thing you did FTW!buckshot what do you think about the weber carb?
IIRC, it's Mr.Gasket part#1937. Not positive though. All the info I have found is in the link, look for the post with lots of links. It might take some time to sift through all the info, But if you keep a notebook & record the details pertaining to your needs it will be worth the effort. One thing about the adapter that may not be mentioned. When you get the carb you'll be using, match up the adapter to the carb base. If it does not cover the drivers side totally, (there may be a 1/8" gap, mine had this) there is a trick using J-B weld epoxy. you clamp A piece of plastic to the carb side of the adapter & make a J-B weld extension between the bolt ears. You will know once you see it & not all MC2100's have this some match right up. Also see the note in those links about plugging up the thermal choke passage in the carb using J-B weld, otherwise it will leak vacuum.where did you get your adapter plate or does it have to have one?
