ScottR
It's never done.
- Mar 21, 2005
- Raleigh, NC
I am selling the full cage out of my TJ. This has the stock B Pillar and the stock bars in the rear that are for the C Pillar. All other tubes are 1.75" .120 wall tubing. This cage goes through the dash and bolts to the floor (can tie into frame easily). This keeps more leg room for getting into/out of the jeep vs the stantion type cages. It has a dashbar, grab handles, harness bar with top half supports and rear harness bar (adjustable, removable) and lots of gussets.
This cage and aluminum roof works with a stock soft top. The door surrounds have to be modified some. I ran the cage with a hard top- it fits great. I never had a chance to run the aluminum roof with a hard top- so I am not sure if that will fit or not under a hard top. It is very easy to remove the roof from the cage- stainless allen bolts with captured nut tabs on the cage. The aluminum roof is 1/8". The two seams were welded by NTK Fabworks. The roof was a great addition. No more flapping from a cloth bikini top!!
Here are some pictures- let me know if you need to see from different views. The cage is out of my Jeep- ready to move!
Located near 540 and Leesville Road in Raleigh (near RDU Airport). Can deliver a reasonable distance.
$1000
$1000
