retroedaddy
Infidel
- Apr 7, 2010
- Bahama NC
I was having a problem with my 1995 wrangler Jeep 2.5 liter,5 speed,where it wouldn't start cold.Once it had been started it ran fine and could be cut off and restarted easily.It has slowly gotten worse and worse,now it just won't start.Everyone said Fuel Pump,which was new in April.I went out and got starting fluid and sprayed it down the throttle body,it won't start with that.So I suspected Spark,I tested it and sure enough no spark.I tested for 12V at the Coil and there is definitely 12V's there.So I am curious what y'all would do next?Could it be the coil?Dist?Crank Position Sensor?Also,there was a rectangular black block under my fuse box and I took it out because my buzzer was going on non stop.I don't know if that was some sort of ignition kill or something,but it ran after I pulled that piece.It's just the only thing I can think of.Any Info is greatly appreciated.
