Just another YJ build
Just sprung over? I am on the fence for Rancho springs or waggy stock springs and run SUA. I want low and trimming stuff is not an issue.
Those pictures are just sprung over with stock springs. It sits a little higher than I expected, but the rear is lacking about 175-200 lbs since the fuel tank has been removed. I plan to 'raise' the springs hangers up on the frame as much as possible and move the rear ones rearward about 6", and the front ones forward about 4-6". I will also mount the shackle hangers high up on the frame ends to 'lower' the rig as much as possible. If you have ever seen pictures of my Samurai, you know that I have ZERO problem trimming sheet metal, LOL.
I mounted up the new wheels and tires to get a baseline. It measures 25" to the frame right in the middle. It has a bit of a rake to it because of no fuel tank and fuel, and no spare.
That looks great. I love the old school graphics > you should try to keep the body as original as possible IMO.
And cut those shackles! :eek:
Looks good.
I assume there is going to be trimming of some sheet metal in the near future?
Dat azz tho… :smokin: Sorry, it was the first thing that came to mind when scrolling past the rear view pics. Looks awesome!
Front forward 5", and lowered about 2.5". The wheelbase should be about 103.5" in these pictures. 22.5" to the bottom of the frame with 20 psi in the tires. I'm guessing it will be 20.5-21" with trail pressure. This is pretty close to how it will hopefully end up after figuring out shackles, steering, etc.
