BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
What is everyone's thoughts on a K5 Blazer for a trail rig? Too big for URE? Known issues for the mid 80s version? Looking for any and all opinions or thoughts.
. In regards to the 454, it is carburated, which I am not extremely familiar with, will it have fuel delivery problems at anngles?
The Front should be a 8 lug Dana 44hd. The rear could be a full float or semi float 14 bolt. Like stated earlier cucv axles would be a direct swap if you wanted to go to a 60 front and a full float rear. If its got a quadrajet carb it'll do decent off road but if the motor is stockish (ie no wild cam) then a throttle body injection swap should be fairly straightforward. I'm running TBI off a 350 on my 351m cause I got tired of dealing with flooding at angles.Thanks guys! Main thing I like about the K5 is the removable top and that there is enough room for someone my size even with an interior cage.
I am actually looking at one that has 14 bolt rear and (per the seller) "3/4 ton front axle", which I am assuming is a D44?? It is already lifted and running 38s, and has a 454 swapped in. In regards to the 454, it is carburated, which I am not extremely familiar with, will it have fuel delivery problems at anngles?
I love my K5 & it has all of the stuff mentioned above since it is an 87 w/ a TBI 350, 700r4 & alum 208 case. The only issue that I have had is the front output bearing going out in the case, which can happen to anything & as mentioned they are plentiful & cheap. I am running the CUCV axles w/ detroit's in both & the stock 4:56 gears. Lifting them is cheap w/ doing a 52/56 spring swap which will give you 4"lift.
The small block has plenty of power & the 454 that you mentioned is easliy converted to TBI with all fractor stuff, then you won't have to worry about angles & reliablity.
The down side is, it is a fat pig. URE is no problem & you can wheel all of it w/ no body damage. But the Flats & Harlen are a completely different story. Expect body damage from the headlight's to the tail lights. But I enjoy people saying how did you get that fat pig up that trail. Just get use to the crushed tin look.
Also towing becomes an issue. I weighed mine before with no top, no doors, no interior other than seats, no spare parts, 1/2 tank of gas & before the bead locks & full cage, it still weight just over 5500lbs.
There also not a complete bolt on build like most Jeep projects, so get your fab skills out.
i love my k5. i personally felt it was too big for uwharrie, only because the body was in such good shape i didn't want to tear it up. if it was just a wheeling rig i would take it anywhere.
Yep figure 1500-2000 lb trailer weight to be conservative or weight it then subtract that from the 7000 gtwr. My shortened 78 f150 with tons and 42s exoed with no bed and rear coilovers weighs about 6300. Its a heavy pig. But I've been wheeling it for years at 7200 so it feels light and nimble now lol!Keep the info coming, I appreciate all of it.
I hadn't thought about the trailer. Mine is a Kauffman 7k, which I guess could be maxed out with a K5 with tons and a cage. My tow rig should be ok, but the trailer may need to be upgraded, dang.
