Tacoma747
- Mar 20, 2005
- Winston-Salem
I thought I posted this up earlier, but apparently it didn't work, so here goes again:
I have no way to mount a limit strap on the front suspension directly over the center of the axle, because there is no room (oilpan, 3rd link, etc).
SO: I was thinking (might should try not to do that so much), would it work if I ran a strap from each side of the truck (under engine mounts) down to the center of the axle?
Seems it would work fine to limit droop, but when the truck flexes and the trac-bar pulls the axle to one side or the other I don't think it will work too well?
Any ideas or suggestions? Think it will work just fine and I am overthinking it, or it won't work at all?
I don't need to limit shock droop (I do, but that is easy), I need to limit full axle droop. When I pull up to a rock it lifts the whole truck. I knew this would be a problem, just wish I could use the winch to pull it down...
LOL
