This had 45hp due to the restrictor requirement and went 0-60 under 3 sec. I would have a blast driving a cj2a, a 6.2 would be fun, but it would take a lot of beefy parts to lay those ponies down and be reliable. Depends on what you want from your rig.
Would I love to drive a trophy truck, he’ll yes. But I can be happy with a lesser vehicle too.
I used to work for schaeffler (makers of luk clutch which is oem jeep) the internal slaves on the aftermarket or post production had a high incidence of warranty returns. Plus a stock Bellhousing and input are not always easy to find when 90+ percent of a model come in auto. The ar5 had 2 Bellhousing a. 1 for Isuzu ecotec 4 cylinder and vortec 4,5,6 and one for the v8, different input length and bell pattern on the 2. As far as I know, Colorado and and h3 were the only ones available in a pattern that fit behind the ls. Not saying unicorns don’t exist, but you have to get a hold of one, and factory bells are thin aluminum. I’d much rather trust a beefy aftermarket unit
Another thought is the Toyota trans had a steel mid plate capable of over 450lb ft and the jeep ax15 and ar5 used aluminum to save weight which isn’t as strong so they are rated at 300lb ft mixing jeep tail housing with Toyota mid plate (front cases are the same) and whatever internals give your preferred ratios would be a sweet unicorn!
That being said, I’m using a 4l60e with internals from an Escalade to match the power of a 4.8 since that’s what came behind it factory and I know parts availability will be there. Plus I don’t wanna look like a tool when I can’t figure out how to feather clutch in the rocks
4.8 QuickDraw ax15 is a good combo as long as you leave that ls stock
