More XJ issues
I went to the dealership yesterday morning to get or to order the hose that busted. The reason he did not see it on his computer is that they do not make it like that any more. It now comes in four pieces that has a different part number. He said it would be about $150 for all of it. sooooo
Today I go to the parts store, and tell them to step away from the computer, and let me at the hoses. I will piece together something that should work.
If the Throttle Position Sensor is not adjusted properly(I'm assuming it is a 87-90). The trans will not shift with a scan tool it should read 12-13% throttle. If it is then the trans side of the TPS is bad notice there are 2 connectors to it.
Injectors from a 93-95 Cobra will fit on a Renix intake and fuel rail but they are not needed on a stock 4.0L, stock 86-95 injectors should work with no problem as they are 19lbs/hr.
