Mounting a removable winch to a trailer?
BigClay
Knower of useless ZJ things
Winston-Salem
I am looking for ideas on how to mount a 2" receiver on the front of my trailer so I can put my multi winch carrier in there if need be. Anyone done this? I don't want to leave a winch on the trailer all the time, but it would be nice to be able to slide it in the receiver should I need it.
Oh gotcha most mounts that the manufacturers make are just flush with the floor and extend forward of the deck. I added a winch for a guy at Church and I welded in c channel under the deck between the crossmembers and bolted it down through that. I would think if you just came off the front with a piece of 4" channel would give you plenty to weld to.
This is a crappy picture but this is something like I am thinking. This way the winch is not always on the trailer. Only probably I have is I have a 5 ton jack welded right to the center of the front of the trailer (on the outside), so this type of mounting won't work for me.
awww.polarisatvforums.com_forums_attachments_atv_general_discu8fb4cfd130249656008adc50aa2d0fcd.jpg
Good point, didn't think about a car, was just thinking about my jeep.
this
ascontent_iad3_1.xx.fbcdn.net_v_t1.0_9_11225074_10207474497285ac231bd1d5586f8c1ab2c1ae088949c7.jpg
May want to consider a roller in the middle of the trailer where the dove tail starts or at the end if it's a flat deck to keep the cable from rubbing grooves in the metal frame
another good point, I have a wood deck, so it would gouge it pretty quick.
This brings up another question, is there any benefit to having synthetic line on a trailer winch?
I have a flat deck and winch mounted on the front with steel cable. I haven't found where a roller would be any benefit. My trailer isnt gouged at all and the cable has zero burs.
I think for durability, a steel cable would be best but not as safe as the synthetic rope.
X2. I have a dove and it rubs the break but didn't hurt anything.
My trailer sits higher than a typical car trailer and when pulling lower riding stuff up on it with a come along the cable rubs pretty hard. If my trailer was lower it probably wouldn't be a big issue or if you only used it a couple times a year then you probably wouldn't need to worry with a roller. But I have seen higher riding trailers like mine that get used alot with grooves worn into the frame. Mine doesn't have a roller but no often than I use it that way I doubt it will be a problem.
What if you make the winch mount on a post and weld a receiver tube vertically at the front of the trailer. Think of a hidden gooseneck ball when the winch is removed.
I would worry about ruining the synthetic rope from dragging on things. The difference between rolling a vehicle up on a trailer and doing an extraction in the woods is that there is a significant difference in the amount of pulling force required between the two operations and safety/durability are more important in the woods. Unless you are planning on dragging things up on the trailer that don't roll then you don't even need that stout of a winch. I have a basic 4700# Warn utility winch bolted to the winch plate on my trailer. I believe it has 1/4" wire rope on it, maybe 50' worth. It is always more than enough to tug rolling vehicles up on the trailer.
