Mower dies after running for 20-30 minutes
And the saga continues...
It was slow to crank a couple weeks ago, battery was weak, so put a new Sam's Club Duracell in it, now it busts right off! And ran for like 1-2 minutes, started stumbling, died. I had not put a fuel filter on it yet, so I went to O'Reilly and picked one up, figured some junk had clogged the carb. Pull the carb off, clean it up, install the filter, cranked right up, rn great for about 4-5 minutes, then just died almost instantly. It was by the porch, and the wife was on the porch swing so we talked for a few minutes and she commiserated in my sadness and frustration, then it cranked and ran enough to get 2/3's of the way back to the shop. I sat there and searched marketplace for mowers for about 5-10 minutes, realized they are just way too expensive, and decided to fix mine, but it wouldn't crank and I needed to get it to the shop. The side by side said "ok". :laughing:
Pulled the carb and this time there was a nice mix of gas and muddy looking water in the float bowl.
I pulled the line off after the fuel pump and watched it pump some stuff that looked like muddy water too. Aha!
Pulled the fuel guage and looked in the bottom of the tank on the "good" side that was empty:
Other tank was also full and looked the same. Those plastic things are fuel cap retainers that were dropped in and never retrieved by the PO. While not ideal, I couldn't get a bite on them to pull them out, but the shop vac and some brake parts cleaner took care of everything else. In the end I pulled both tanks off, siphoned 5 gallons out of 1, and cleaned them nearly to perfection. In the 5 gallon tank that I siphoned out and it was drawing from when it died, I ended up with this:
And of course there was more that had already been through the engine and in the carb and drained out. No idea how that got there, or how long it has been there, but I'm 100% certain it wasn't helping anything :D
Cleaned every single line, filter, carb, and fuel pump, pulled the tank pickups and cleaned them, etc. So hopefully I'm FINALLY done f'n around with this thing and can just cut my too tall grass. Of course it was after 9pm by the time I got done fiddlin with it, but I cranked it til the completely dry fuel system primed and the motor cranked, then cut it off. Tomorrow will tell the tale.
Considering our 60” ZT Bad Boy is now doing the same things from your OP…and we are here now. I hate you because I’ve been avoiding cleaning the whole fuel system. Mainly because the carb is behind the rear “bumper”’and I have to disassemble an unreasonable amount of things to access it.
No idea. It wasn't actually muddy, but had an orange tint to it. Seemed to just be water. Maybe it's from washing it at some point recently that I don't recall haha.
Have you replaced the fuel cap? You said those are fuel cap retainers in the photo. Any chance they are the cap gaskets as well? Is the re a vent built into the cap that’s allowing water in?
I’m sure you’re on top of the world about this fix.
No, caps have been on it for the 5 or whatever years I've had the mower, and the gaskets are in good shape. I did replace the fuel gauges, and they do have a weep hole in the top, but I park it under my shed, so I don't think its rainwater.
I'm so stoked that if you still lived in NC, I'd come cut YOUR grass! :D
I bought my dad new Eagle cans because of this shit. He stopped up the tractor with a random can of diesel he "found." It took the better part of a year to get it sorted, including pulling the tanks to replace the pickup filter.
