Nissan11
- Nov 29, 2005
- Marston, NC
This is a rehab plow. It's job is to go in behind a plow that was used to put out a fire and smooth the two big berms out by throwing them back into the ditch the first plow made. This works well but it is about 12-14" too narrow on each side. As you can see from this pic, the outside disk does not reach the outside of the berm.
The company that made this plow went out of business 20 years ago so I am unable to consult with them. The IDEAL setup would be to be able to use the single furthermost rear cylinder to extend both disk gangs so that the width can be adjusted for going inbetween trees, but I just don't see how it is possible to accomplish that. I can not add a third cylinder because our dozers only have 4 hydraulic ports and two levers. That rear cylinder is currently used to adjust the angle of the disks, which I really don't need because the angle they are currently at is the only angle I use for plowing.
[URL=http://s130.photobucket.com/user/nissan11/media/Mobile%20Uploads%202/20151214_133014_zpsjxiopbdu.jpg.html]
[/URL]
So, my idea is to cut the two mount plates per side that the pivot pin runs through and shorten them. If I do that I can simply move them 12" to the outside and weld them back in. If I do that, I will have to cut another hole in the rear frame rail for the bolt mounted on that rail.
[URL=http://s130.photobucket.com/user/nissan11/media/Mobile%20Uploads%202/20151214_133030_zpsoxvfjxrv.jpg.html]
[/URL]
[URL=http://s130.photobucket.com/user/nissan11/media/Mobile%20Uploads%202/20151214_132959_zpsgfskkosm.jpg.html]
[/URL]
[URL=http://s130.photobucket.com/user/nissan11/media/Mobile%20Uploads%202/20151214_132948_zpsbgwt847t.jpg.html]
[/URL]
If I am able to do all of that, I can weld an extension to the end of the gang frame, cut off the old tube and weld it back on to the 12" extension which would allow me to still control the angle. I would also be able to use the exisiting heim joints and arm.
Does anyone have any better ideas for making this disk a total of 2' wider? This is very thick material as well. If my plastma cutter can not cut it then I can not do it. I really dont want to butcher it up with the oxy/acetylene.
