BadMagoo
New Member
- Mar 2, 2006
- Wilmington, NC
I have a stock Wrangler TJ (4.0L/3.07 gears/Dana 30F/35R) that is my daily driver. Soon, I will be installing a friend's 4" trailmaster lift and putting on 33s. The objective is to go to Uwharrie National Forest this summer and have a good time. The problem is that I have enough funds to do only one of the two necessary mods that come thereafter. I can either install a Slip Yoke Eliminator/CV Driveshaft or regear to 4.56.
I live in Wilmington and I take occasional trips to Winston-Salem and I'll have to get to UNF every so often. Therefore I do need highway capability.
I am worried that when I put on the lift and drop the transfer case, it won't get rid of the driveline vibrations. Don't want to end up with a death wobble if I go over 60mph! I definetely see the need for a SYE/CV because I hear that it eliminates the vibrations all together.
The other part of my problem is that if I get the SYE/CV I'll be broke for a while and most likely be going to uwharrie with 3.07 gears. I gather that 33s and 3.07 gears makes for a disaster on the trail. I just moved here from Colorado and it was bad enough rock crawling over there with the 30" tires I've got. I couldn't crawl on much of anything, I seem to just ramp over top of things. Highway driving doesn't sound too favorable with 3.07s either, after I'm lifted with the 33s.
In your opinion, which would be the better buy under my situation? The SYE/CV or changing the gear ratio with my existing Dana 35 Rear? Or hey anything else that might help me, I'd appreciate it!
Thanks!
Thanks!
