- Mar 20, 2005
- Hendersonville, NC
Stroker
Dude was born to race
Stroker
Had a mean streak two feet wideDude was born to race
Son of a gun with a taste for fun and more than his share of prideHad a mean streak two feet wide
$450 including machine work and professional assemblyIt's $1k above and beyond whatever you'd spend on a standard rebuild. You can spend a lot more, you can spend a little less, but that's a solid budget number.
Scat crank is $495. Might could buy a 4.2 for less, but then you've got to turn and balance your junkyard crank, plus probably change the snout or buy the spacer. It gets really close to even.
Pistons cost more, valve springs and keepers cost more, rods aren't free (and again, resizing used rods gets you damn close to cost of new), etc.
Again, you can do it for less, but $1k is a solid budget number, not an "I scored a clean 1990 4.2 for a case of Natty" budget.
Doesn't he know I want to argue about it?you know he's trolling you right?
I heard he took a dirt road curve with the devil's nervesSon of a gun with a taste for fun and more than his share of pride
Makes a car dance as across the mud too!I heard he took a dirt road curve with the devil's nerves
I can have a built LS installed by Hendrecks Racing for a grand.Scat crank is $495. Might could buy a 4.2 for less, but then you've got to turn and balance your junkyard crank, plus probably change the snout or buy the spacer. It gets really close to even.
Wtf I got mine installed for $500 at Hindrecks.I can have a built LS installed by Hendrecks Racing for a grand.
