Though i'd put in my pennies worth.
Well, I have read through your post and thought I may have something to add that's a unique perspective on the subject. I'm actually the youngest son of Larry Sperberg and having been around his work all my life and this debate is almost second nature to me. If you’ll indulge me, pull up a beer I’m going to get on a soap box for a couple seconds.
With concern to most of the posts, most are taken from the stand point of immediate or right now as it’s happening and a while in the “action of perspective†stand point; it is true that most organized racing of sorts usually run nitrogen for it's convenience and stability as well as it's predictability and consistency factors.
But how nitrogen affect average people in their every days is different. People in Nascar and IRL and other big racing organizations use it for the afore mentioned reasons for those main benefits as well as others. As it trickles down to the rest of us it's hard to see why it's beneficial and superior filler.. Reasons are simple. We use our tires for more than one event at a time. Professionals use several sets of tires at any one given event. Most weekend road warriors will maybe get a couple of races out of a particular set or unit. (maybe a season if their lucky) People like you and me it's a harder sell cause it's simply not sold right. For the crawlers, mudders, boggers and sand devils out there you feel it’s harder to justify cause you’re going slow, not building up heat and so forth. For the most part I think there was one maybe two posts that even mention outside forces and nature. We don't live in controlled environments, we live in the world and as your oxygen filled tires get old and oxidized they get harder and breakdown faster. Most guys out there have had blow outs, bursts tires, punctured tires and the other types off tire failure on the trail or to and from it. Most of the time it's not on a new set of tires. And good portions of tire failure can be attributed to fatigue and breakdown of rubber compounds on a microscopic level. An easy way t think of this is cheese, specifically Swiss. now Baby Swiss has smaller holes through out it. this is the natural tire as it's produced and manufactured. there are microscopic holes in everything. Now as Swiss gets older the micro organisms continue to do their thing making these holes bigger and the bigger they get the stability of the block decreases cheese also gets harder. Both of these are just like tires as tired get older and as more oxidation happens it weakens the tires walls surface tread. it permeated the cell body and can create separation from the tire body and the cording. and eventually breakdown. so pop goes the tire and off to the store with you to buy more. Now nitrogen is not a cure (there is no cure, but it's a aid in your favor, like medication over time it can help you and your tires get better or stay healthy. Individual examples (and I’m lumping here) are muds/bogs/crawlers you guys buy your tires to be bigger, somewhat soft to ensure maximum grip, bigger (I said it twice cause they are quite big) and wide foot prints to ensure grip or taller walls to allow you get reach when flinging the muck. So after a year of two and a couple of seasons have passed. Beside the obvious tread wear, your tires don’t seem as soft as they were when you bought them. They don’t bounce like they used to when your diving. They don’t have as much give or play. Most of this is due to oxidation. Oxygen and water molecules permeating through the rubber and freezing when its cold, oxidizing because that what oxygen does naturally, otherwise we wouldn't have to have paint on cars. It weakens the wall bodies and generally puts you at risk on your everyday drive and on the trail. Glazing and hardening your tires so that grip you need for your foothold would keep you on the rocks instead of flipping head over ass. For the Duners and Dessert Monkeys you pretty much deal with the glazing and decresed deep cutting/scooping aspects of your tires in the sand and byproducts from oxidation. Unless your doing it in the winter too in which you are really hard-core and are getting the full effects of crappy tire performance.
As for passenger vehicles what if the Firestone recall could have been reduced because the industry used nitrogen instead of oxygen and the tire separation wasn’t as severe and they were able to catch it at a cost of fewer lives and less hardship. What if goods we buy weren’t affected as much by the cost of transportation (upkeep on vehicles is one of the biggest costs in the professional trucking world. And truck tires at a several hundred a tire is costly) {most large fleets are maintained with nitrogen by the way to help reduce such costs} As for you or me people solutions, most people don’t replace their tires every one to two ½ years like they should. (optimal of course) They go three, four or when ever the damn things run down. But when you go this long it’s worse cause oxidation and degradation is not a linear thing. It doesn’t keep happening at the same rate until you take them off and get new ones. It exponential and it’s on a curve. In the beginning it takes a lot to get them to start to wear out but as time passes they wear out quicker and quicker and degraded faster and faster. We run them every day on and off several times a day constantly heating and cooling, heating and cooling. And as the water heats and cools it does its job and wear’s them out. Then it becomes that blowout that we’ve seen on the highway that the family was inside when it happened (it could be yours, is it really worth the risk??) (I don't recall the figures but there are thousands upon thousands of accidents and fatlities created by premature tire failure every year)
I’m not here to sell nitrogen inflation and definitely not to sell tires, I hate spending the money just like everyone else, but I’m also aware what it can do and what can be the costs both physically and monetarily; I choose to spend the money and be proactive to fight it off as much as I can.. We are not a proactive or forward thinking society and hardest thing about it, what can be done about it? Sad to say at the present not a whole hell of a lot, gas stations won’t install nitrogen fillers because they’re too costly or rather they can’t make their money back as quickly. (in northern Europe and Scandinavia they have begun filling stations with nitrogen fillers as early as 86/87 [that was a push by private industry and the Gov. due to increased accidents in inclement and cold weather climates for improved safety on their roads and highways, I guess they figured frozen tires on frozen roads is a bad thing] but oxygen is still the prevalent choice for stations, In the United States I don’t think there is one nitrogen generator for tire fills in the whole country). As with most things it comes down to money and how much it will cost and how much can I make from it, it will never be about the benefits.
I hope you find this useful and most importantly informative. Information and knowledge are the only way to combat anything. For a farther in-depth look, Google or Ask Jeeves on my dad’s name, (Lawrence R. Sperberg and variants of it) you’ll find several sites with his papers on Nitrogen inflation and other such things. Rally your communities, your local 4x4 store and passenger vehicle supply stores. If you and your friends don’t start asking what other can help you do to keep you and your family safer, they never will of their own accord. Also, if it became the standard instead of an “alternative option†it would be become cheaper.
I leave you with this. If you do not begin to take your own life into your own hands and do what you can to protect it, who do you expect will?
Thanks guy’s I look forward to seeing you on the trails.
R.
(if you though this was wild, start looking up hydrogen combustion engines that use most of the same engines we use now and which will be on the roads in Europe in 2006, [dual-fuel capable BMW 7 series] but yet the big three are pushing lower horsepower, wastefull energy, more costly petroleum derived hydrogen fuel cell pellets that will be here in maybe 2010?? Replacing the entire way cars are manufactured and runs instead of just changing the fuel it runs on?? Does that make sense to you?? They're going to make billions though, at least they'll make money. Too bad we won't, we're just going to have to pay for it.)
