Gunna give this a try as well
"I hope this might help other blokes not to spend hours on the forum trying to work out why the darn thing won't fire up:
The exact same thing happened to me, it just died on the motorway. Symptoms were: It would turn but it wouldn't start, fuel and temp gauges remained at 0, key transponder light was on and "no bus" displayed on the odo. After checking all relays and fuses I read that it could be the cranshaft position sensor so got a new one from the dealership, replaced it and it fired up right away. If you experience similar symptoms follow the wires from the sensor and unplug it from the harness near the back end of the fuel rail. If your gauges go back to normal you've found the culprit."
