No Power Steering Still After Pump And Gear Box Replaced?
72Rockcruiser
LETS GO BRANDON!
Charlotte, NC
So after a short wheeling trip a while back with the front locker engaged(and 38's), my 97 Land Cruiser has had no assistance from the PS.
I have(finally) replaced the pump, installed an overkill cooler, and even replaced the gear box. STILL no PS?
Also filled with new Royal Purple fluid. Thanks Will! :flipoff2:
I am stumped. No noise, no whining, no bubbles in the res. Turn the steering wheel lock to lock with tires off ground, no binding.
Just no help from PS.
Any help is appreciated.
Thanks!
Good call, Alex. I did order a new pressure hose, thinking it may be blocked, the return line is no longer available, so I will blow it out when I replace the pressure hose.
This is pretty much the last thing keeping me from going wheeling, so wish me luck!
Where did you get the pump/what brand? Rebuilt pumps actually work about 1/4 the time in my experience.
Low mileage used factory Toyota pump. Did not buy an aftermarket pump for that exact reason.
Also, may be important to add, this engine (1FZ-FE) uses a gear driven pump driven by the timing gears.
Pics:
