ManglerYJ
- Mar 20, 2005
- Lexington, NC
zubz said:Matt,
I think you have a good conceptual idea. However, $4500 will never work in reality. Not trying to be a wet noodle but realistically you will not be able to build and put together this project for that. At least not to the point where you are wanting to be.
One major point you are gonna have to deal with is the fact that you are going to have to find a good, dependable supply for the motor/tranny setup. If someone is buying a brand new toy for $4500 they are not gonnna want the 100K mile motor/tranny you can buy for $500.
What are you going to do for suspension and steering? Full hydro?? That is $500-750 easy right there. If mech, you are gonna need to find a source for excellent condition boxes and that will be at least $500 with shaft, column, box, etc. What about suspension??? Links and joints adds up fast. Leafs can to if you have to buy aftermarket......Used would not work for your target market.......
Building a "Like New" set of axles with gears/lockers and a JY housing(assuming you can find a super cheap, good supply) will be at least $1000(gears, lockers, new brakes, bearings, etc.).
Figure $2K for a set of Beadlocks and Tires........at a minimum if you are using new.
Driveshafts???? $500 at least......
I haven't even talked about the chassis yet.......
Just trying to be realistic because I don't want to see you get a bunch tied up in this without it being realistic and it turning into one of those projects both of us have dealt with in the past.......
HTH
Andy
You bring up a lot of good points, most I've already considered, others I haven't. As far as the suspension, you know me, I like to keep stuff simple and low cost so leafs in the front and rear or a 1 link rear is what I was shooting for to keep it simple and flexible (I hadn't made up my mind yet - I'll see in the prototype). Coil-overs are cool, but add a lot of cost as you mentioned.
You are correct that whatever is bought for the prototype will have to be bought also for future models, so it will have to be a reliable renewable source. As far as beadlocks go, I haven't needed them yet in almost 10 years of wheeling, and while I still consider myself to be somewhat of a nivice, I wouldn't expect that on a starter chassis one would require them either. They could be added as an additional cost item, though.
Driveshafts will add to the cost, but they don't necessarily have to be bulletproof Tom Woods shafts. I'm working with a powertrain that will not be high horsepower, so stock parts will be acceptable. If I feel after testing that it will need to go bigger, I'll address it at that point. Again, unlike the $25,000 rig on the first page of this thread, I will not expect to be able to put it in the hands of Chris Durham on a UROC course and expect him to not bust something. This isn't that type of rig. I would expect that a sensible driver will be able to navigate it through just about whatever Uwharrie and similar trails can throw at it.
Steering will be kept simple since the tires will be 33's or smaller. Just the usual power steering for this light of a buggy. No need for fancy full hydro, and no need for rear steer. This isn't a comp buggy. When's the last time you needed rear steer at Uwharrie?
I whole-heartedly agree that I don't want this to turn into one of "those" projects that we've dealt with. I'm trying to do as much research as possible prior to jumping in head first. I will first build a proto-type to make sure the project is feasible. If it's not, I may re-align the numbers to where I can be profitable and marketable. If that is not possible, I have just built a big toy to use in the back yard (arocky/hilly acre and a half backing up to some powelines) and Uwharrie for myself.
They were bigger than ATVs but not as large as a Jeep. Some with full cages, buggy like, some with cabs and smaller cages. Talked with a couple of guys and they have all the gearing, locking, tire options, etc like full size rigs. One guy had 3 on one trailer
