Metto
- Mar 20, 2005
- Cornelius, NC
i would assume that if you are looking at converting 3ph equipment to run in a shop that does not have 3ph power you are likely not going to be using the equipment at a duty cycle that would wear out internals of a VFD in short order.
Similarly, most of the electronics that are not high voltage/current consumption run on 120v in CNC equipment. Most of this kind of equipment has a step down transformer or other device that pulls off a single leg to power those electronics. that part of the equipment could be pretty easily rewired to run of 120v without running thru the RPC/VFD which would remove any issues with power fluctuation.
