RatLabGuy
- May 18, 2005
- Churchville, MD
Ugh. So, have a potential PITA plumbing issue.
Our laundry room and far bathroom are on a 4" raised cement slab that is on the back end of the garage slab, connected to the side of the house.
Somewhere inside this slab, there is a water leak I can't get to. All I know is that there are water lines I can see from the basement that go through the rim joist into the slab. There is laundry and a toilet on the exterior wall, and a sink on an opposite interior wall but the supplies to it come up from the floor, not in the wall.
So, at some point in the floor they must split. All I know is that somewhere embedded in there the cold line is leaking. We didn't even know, I just noticed one day last fall that I could just barely hear water flowing, and if I jiggle the supply line to the sink it changes pitch... and the well pump was running a lot. Otherwise no signs of water. As far as I can tell water was just leaking under the slab. So, we just cut off the water unless we do laundry until I can fix it
Well now water has started appearing in the adjoining basement wall floor seem, so it's time to do something about this...
I assume the *right* way to fix this is to bust up the damn slab, but I don't even know where it is. What a pain.
But I wonder - is there any reason I couldn't just cut off and abandon the existing lines, and instead re-route new ones to the fixtures? That will be a pain too, b/c I'll have to go from a source in the basement all the way up into the attic and across, then down into an exterior wall. But even that seems like less work.
