Well, hit a bit of a roadblock.
@getstucksome came over and helped me get the timing set. Currently timing is set to 0 and it still won't crank. Getting spark at all six plugs. I'm about 99.5% sure that I am getting way too much fuel into the TBI.
Let me explain. When I started looking for a inline fuel pump, pirate4x4 pointed me at a carter p5000 inline pump. This pump flows at a max of 75psi. Multiple people said they ran this pump with their 4.3l TBI and had no issues. Of course I have issues
. The TBI unit needs a psi of around 9-13
. Obviously, I am over pressurized and the fuel is blowing past the regulator in the tbi unit. This results in ALL the fuel being dumped into the TBI unit, no pulse, no modulation. Just a full cone of fuel being pushed into the motor. I got the motor to stumble and "fire" after disconnecting the injector wires and it running on gas that was in the manifold. Additionally, I would have gas coming out of the exhaust in decent quantities. Another bit of damning evidence was the return line having a solid stream of fuel when the pump was primed, instead of a little dribble.
So, I've got another pump on order that flows a max psi of 14. Plan is to pick it up this afternoon and get it installed. Here's hoping it will start right up...
