- Mar 20, 2005
- Morganton NC
yes, it's a dual fuel system. I have seen them but don't know how they work. www.propaneguy.com has them
Gusagus said:any way to set up pane so you could also still run gas? like for example run out of propane and there is'n a filling station for miles but your at a gas station with the 6.00 a gallon and need to get home.
With duel fuel you basicly have a gas carb that also has a propane inlet or a gas carb and a fogger plate.You have switch that ether turns on an electric fuel pump or lock off valve kinda like having two gas tanks on your truck. Sounds real simple but they are junk. When you run LP the gas part of your carb runs out of gas and we all know how much fun a carb can be that has sat for a while not to mention the black tar from the LP stoping up the gas jets.You cant get it to run right on both. If you tune it to run gas its a dog on LP because the timing is low and the plugs are too cold. If you tune it to run LP it spark knocks on gas because of the timing and hotter plugs. Most duel fuel set ups I have seen ran on LP or gas but very rarely both.upnover said:yes, it's a dual fuel system. I have seen them but don't know how they work. www.propaneguy.com has them
