SHINTON
- Mar 17, 2005
- Triad area of NC
Ok...so you purchase a new set of tires, in my case, BFG A/T KOs, load rating E...and they are rated about 3715lbs at 80psi. (COLD it says, 80psi cold...)
SO...the question is...how much PSI should I use around town (non towing) and should it differ for towing?
I got the tires today...thought I felt a little bit of "rolling" and wondered what PSI he put in them. Got home and checked and they were all 50psi. (Fairly warm to the touch...not HOT but warm) Was a bit surprised to see they still had that "bit flat" look at the 50psi, but the Ex is a heavy mutha, 8000lbs easily with the junk I got in it) Still has it a bit on the front even at 60psi...
I added 10psi, putting them at 60psi. I just wanted to see what the gang here had to offer....should I be running at 70 or go ahead and run the rated 80?
Towing this weekend will be pulling a camper, about 6000lbs or so...(w/d hitch)...
Sam
Sam
