untchabl
I like rocks
- Mar 30, 2009
- Bear Creek, NC 27207
$19.95 6.0 swap in progress
They've been hanging out in your shop around all the big boy axles. I just hope they don't get "small axle syndrome" and not perform later.Dumpster's full. Thanks to @AdamH
But first.
An den.
Had to rig up a hub puller. I lent out my actual AMC 20 hub tool and never got it back.
Hubs off, I ain't dead.
Bored and playing with chatgpt tonight. Figured if they're going to destroy stokes county with a huge AI data center, I might as well make it worth it. LOL
Except for the massive amount of energy to run and cool them and the physical space they occupy that was once a cow pasture, me neither.I don't get all the pushback on the data centers. Im not a fan of AI and mass surveillance that *some* are used for, but the buildings themselves are not a bad thing.
Here is one good exampleI don't get all the pushback on the data centers. Im not a fan of AI and mass surveillance that *some* are used for, but the buildings themselves are not a bad thing.
This is a bit coin mine, but same principle applies.
More and more data centers are being built off the electric grid powered solely by onsite generation. That will have a massive impact on fuel (diesel and NG) prices soon.
Currently 18% of all the NG consumed in SC igoes to 2 addresses for just this reason.
The new plant being built in FtMill requires 1 gigawatt of electricity.
From what I've read, the data center in Stokes is supposed to require more power than the current residential power demand in the entire city of Greensboro. I'm almost certain Duke Energy will pass the required infrastructure cost onto us.I don't get all the pushback on the data centers. Im not a fan of AI and mass surveillance that *some* are used for, but the buildings themselves are not a bad thing.
ChatGPT says peak demand for city of Greensboro is 800-900MW. Which to match that, depending on the client, would mean a DC campus of at least 12 buildings at their peak demand, which is quite large.From what I've read, the data center in Stokes is supposed to require more power than the current residential power demand in the entire city of Greensboro. I'm almost certain Duke Energy will pass the required infrastructure cost onto us.
I'm not sure what kind of cooling equipment or process they will use, but I'm sure there will be potential for large amounts of nasty to wind up in the river a few miles upstream of my place, if there is a failure in their equipment.
Probably a 4.8.$19.95 6.0 swap in progress
That cooling will gobble up a tremendous amount of water though. Cant cycle that cooling tower water but just so many times.I agree that the responsibility for upgrades should be on the customer that needs it.
The cooling is not my specialty, but I dont think its anything any more nasty than the cooling for other industrial purposes.
Depends on use case and client. Some use WAY more water than others. Most AI DCs also depend on closed loop liquid to chip cooling. To @awheelterd point I'm not sure what the refresh rate is on those closed loop systemsMost of them now are not as water intensive.
Im sure they use some sort of chilled glycol in the building, but the heat extracted from that glycol has to go somewhere. Not like they have a huge geothermal system. They seem to gloss over how they actually get rid of the heat from the building, just focus on how they are not using traditional air conditioningDepends on use case and client. Some use WAY more water than others. Most AI DCs also depend on closed loop liquid to chip cooling. To @awheelterd point I'm not sure what the refresh rate is on those closed loop systems
CorrectIm sure they use some sort of chilled glycol in the building
Reminds me of thisThat cooling will gobble up a tremendous amount of water though. Cant cycle that cooling tower water but just so many times.
You'd be wrong.I dont think its anything any more nasty than the cooling for other industrial purposes.
Real data centers are redundant utility fed from separate sub stations and have full on site back up usually to an n+3 level…gotta chase those 5 9’s or uptime institute will thumb their nose at youYou'd be wrong.
A.I. racks use water cooled processor chips.
Where before, you'd be using hot deck/cold deck air to cool a rack, now you also have to inject cooling water/glycol into the processing chip inside the rack. Multiple chips per rack.
Not only is this calling for MASSIVE amounts of chilled water for air distribution, but now chilled water for processor cooling.
And the power that this data center must be reliable. Reliable means THEY GET POWER BEFORE YOU in the event of an outage or brown out.
Think of the ocean water processors in the movie oblivion
That's an A.I. data center. More resources than you could ever imagine go into making them function
*Ron, Oblivion is a Tom Cruise movie.....Tom Cruise is a famous actor.![]()
