Aaron871
Member
- May 11, 2005
- Charlotte, NC
RufusTheRam said:third, there's no axle seal there.
you should have an inner and outer axle seal
or am I misunderstanding?
RufusTheRam said:worded that wrong... meant where the stub axle goes into the hub/bearings where the thrust washer is. with aftermarket greaseable joints, it's possible to run them without packing a damn tub of grease in the knuckle at least, but i would still run the boot to keep mud/water out. without boots, i think wheel bearings would go quick, as would the kingpins without constant lubing through the zerk. probably be okay if you lived out west, but not here.
SSWaters said:Aaon, I run a spool in the rear now and was wondering if you've broken a rear shaft on the pavement. I'm thinking as light as my Jeep is I shouldn't have to worry about it. Just turn wide like I do now and either stay in or out of the gas when turning sharp. It sure drives straight down the highway better with a spool .
Scott
jrraw23 said:Just out of curiosity nobody really clarified why pinion brakes are dangerous for the road, could someone clear that up for me?
Thanks
upnover said:From what I was told by someone using pinion brakes, the issue is that it is a dick brake. therefore always having some pressure on the rotor, it builds up heat, and it will make the seal in the pinion fail creating leaks.
besides what's been mentioned, brake fade is a huge issue also. the rotor is spinning 6.72 times faster than a wheel mounted brake, and has half the surface area (1 pinion rotor vs. two wheel rotors). you'd also have to run drive flanges on the front to maintain front axle braking, which would be a pita on the street with a locker.Just out of curiosity nobody really clarified why pinion brakes are dangerous for the road, could someone clear that up for me?
RufusTheRam said:if you haven't broken your 10 bolt with 35's yet, it'll be fine.
RufusTheRam said:personally, i've only got 2 inches
yeah, i'd say that's a pretty accurate comparison... as accurate as such a comparison can be. one wild card you have to consider also is that many of the shafts in these axles are approaching 50-55 years old in some cases, and have been through who knows what kind of abuse over the years. there's always aftermarket shafts in the event of breakage.is the 52" michlins on rockwells about the same comparison to a 10 bolt and 35's
RufusTheRam said:one wild card you have to consider also is that many of the shafts in these axles are approaching 50-55 years old in some cases, and have been through who knows what kind of abuse over the years.
I need to do a write up on my steering.
Basicaly the front:
stock hydroboost pump ($58)
2.5 x 8 ram Tractor supply ($75)
7.8 cu/in dan foss ($299)
Hoses ($40)
The rear:
2 x 8 ram Tractor supply ($68)
Joystick valve Tractor supply ($75)
Saubaru electric power steering pump Junkyard ($40)
Hoses ($60)
I had to extend the reservoirs of the pumps so that I had enough fluid to run an unbalanced ram.
