bottomland4x4
- Dec 8, 2006
- mt airy
well sswaters i could have used it a couple weeks ago!, oh well i know where to go next time!
what is it for? why do some people flip the chunk? is it to make a front a rear?<---( "I want to do that" )Picture lookin down on it, cutting it where the webbing was a real pain;
This would be if you want to drill and tap your housing,
I'm gon'na cut a housing flange out shortly for drilling the chunk if you want.
to reverse what side the dshaft goes in on. I dont remember how they come, but i think its pass drop and this allows it to be drivers side.
I paid $700 each for mine, and dollar for dollar, you can't touch 'em. Locked and disc braked (at the wheels), I'm at $1900. With a pinion brake and a (welded) spool in the rear, I'm right at $1000 for a steering rear. (Wheels are a constant IMO, since you're buying new ones if you go to a 60)
You could do it even cheaper by using the Toyota caliper and Mazda disc..
Dollar for dollar, you can't touch 'em.
Pound for pound, well... it's about 50% heavier than a 60.
But yeah, the third member sticking up a little over 9" above the top of the tube does present some challenges. Patrick's came out low, and mine, well, we'll see.
www.mudprometalworks.com for all your rockwell needs. wheels 2 piece and 1 piece, centers, rim stiffners, pans, boot guards and 4 link kits
"Is anybody running Detroit or ARB lockers in there 2.5's ???"
Most people just weld them, I know a few with Detroits.
Military "Face Loaders"
Firetoy (Tim) ran some for awhile, also, I've seen a few on Chucks Trucks who run them.
All I've heard is you can put the third member in upside down to switch rotation if you need to.
Military "Top Loaders" are just easier to build off of and more plentiful. Plus there is alot of aftermarket stuff for them out there now.
I have some more info to add. I'm sure a lot of people saw the old yellow dodge on 54" boggers at the Marsfab show & crawl Sunday...he is running rockwells with the stock drum brakes...I had been told that you couldn't run them with a hydraulic brake system since they are designed for air over hydraulic...but that is truck is proof that you can. The owner drives it on the road too.![]()
