Rockwells
A small Hijack (sorry), I have to ask, what does ROCKdubs mean? I'm assuming front and rear steering Rockwells on a rig? Sorry for the NOOB question! Thanks!:D
Ricky's attempt to be funny/cool/gangsta.. Kinda like Vanilla Ice, when everyone found out he was a rich kid from Houston.
W/e ya'll are just jealous of the awesome name I came up with, But I mean, not everyone appreciates a true genius at work :shaking:
dub is slang for either something referring to 20 or a "w" in this case a "w" is short for well thus ROCKdubs
In my case it works both ways since i not only have ROCKdubs I also have 20" rims for my 52's and dub is a common nickname for a 20" rim
dub is slang for either something referring to... a "w" in this case a "w" is short for well thus ROCKdubs
OK, yeah, if you're a VW/Audi guy maybe..
Even then, who the hell says "I have Rockw's"? :flipoff2:
So, some tech stuck in the middle of this rant....
When you put a steering Rockwell in the rear of your rig, you have to spin the 'pinion-chunk' from a driver's side offset to a passenger's.
Anyway, the bolt pattern holding the bull gear/pinion assembly down on the axle is NOT symmetrical and not a simple matter of picking it up and rotating the whole chunk 180 degrees.
If you had a gasket, re-drilling the correct pattern on the bull-gear side would be the easier way (and if you could get it level on your bench it would be easier to drill out too).
We ended up re-drilling and tapping the axle-side bolt holes because Dave's gaskets were non-existent and couldn't otherwise devise a way of accurately transferring the bolt pattern...you'll also need to omit 2 of the retaining bolts doing it this way (just 1 more reason to drill out the chunk-side) just because the case design has some reliefs where you need steel to drill and tap a stud.
Not the end of the world by any stretch, just a bit of a last minute shocker if you weren't expecting it.
Dave... are you STILL not done?
:flipoff2: j/k, been following along on the ZR2 board, its really looking good...
Thanks Biggy, yeah it's coming along. Hope to be able to move it in a couple weeks.
Dave
Isn't it about time for Justin/Unbreakable to change his mind and sell his axles again? Maybe he'll sell you what he has. :flipoff2:
If he does hes getting a swift kick in the nuts...that thing has been in the shop for too long.
Haa!...Dave don't mess around! He's already been back from PA a month and has this b-otch driving around on those Rockwells
