Rotate toyota front axle
Lots of grinding
Just grind the weld out where the ball welds to the tube, rotate to the desired spec and weld back up. Sounds simple, but not including a complete disassembly/reassembly, you would have a couple hours worth of cutting and welding, and probably that much time in measuring and re-measuring. I narrowed the long tube on a Dana 44, and just when I thought I had the C in the correct position, I quit and went home. Came back a few days later with a clear head and spent another half hour measuring the angles to make sure it was right. If I were attempting what you want done, I would do one side at a time. Il
