01blktaco
- Apr 22, 2005
- Kernersville
Just finished the swap on the truck this past weekend. Still got to do the drive shaft but mainly done.
They are 33's. Rancho 44044's in the front, All-pro 4" in the back I think, with a 2" AAL. The 44044's are definetly broken in, so they are good for the low-lift he wanted.
He is going to put 35's on it before long though, just gotta find time to make a trip to Galloways.
What is your frame height Josh? From STOCK, he got about 6-7" of lift, because it seemed about 2" higher than his Trailmaster (or tuff country?) 5" lift. I consider that low lift compared to what alot of guys run. He has enough room to run 35's, maybe 37's if he trims some.
With a 23 1/2" frame height, it is not that high.
I don't think he would be able to clear 35's when flexed if he was much lower. At least not w/o alot of trimming. I doubt he wants to cut his fenders out like you did yours
I ran stock Waggy's for awhile, but they sagged before too long. The 44044's on his truck now just have a little arch in them, not much, I would be afraid that with stock Waggy's and the V6 it would really sag. He had said something about running the 44044 top leaf, and some stock waggy lowers, but we didn't, mainly b/c we just wanted to see how it turned out with the 44044's.
I doubt he will change it, says it drives/handles great, and since he doesn't get REALLY hardcore with it he should be fine (until he gets that first big dent).
