Usually depends on the vehicle manufacturer, and if those sensor data streams are exposed over the OBD2 port. There's a lot of variation depending on the year, vehicle, specific OBD2 protocol, ECU manufacturer/family, etc.
My 2004 Subaru may have a different set of available OBD2 data streams than my 2006 Subaru, because one is CAN-based and one is ISO9141-based, and my 2015 Colorado is likely a different CAN protocol than the CAN protocol on my Subaru, etc., and the different ECU manufacturers may have implemented different things over the OBD2 interface in all 3 vehicles, etc. ABS is a different story too, and not all ABS systems can be read over OBD2 either.
The answer is "maybe". The newer the vehicle, the more complete functionality you will usually get over OBD2. That's a terrible generalization, but it's true.
I'll edit my question.
For obd2 systems and my application, and the ECU logic.
The ECU monitors several sensor data streams such as map, maf, cts, iat, egr, iac, 4 o2 sensors, crank sensor, cam sensor, tft, tPS, etc.
Generally speaking, will this unit display this data, if it exists and is present though the obd2 port to ECU communication.
I guess all my posts need a disclaimer saying no one is liable for Misinformation, whether written or applied as to whether this or another product applies to my applications.
Geez.
Fwiw, my application include but are not limited to
96-07 k2500 suburbans
06 Nissan Xterra
04 Avalanche k2500
Obd2 jeep 4.0 year unknown.
I completely understand that what the unit will do varies greatly with what the ECU is seeing and doing with what data is present.
I'm just trying to find out if this will view and clear codes, or will display the data stream and or plot/graph those data streams for individual sensors. This can be beneficial to diagnosing the difference between a po171 code needed a new o2 sensor, or an inconsistent maf signal throwing a false po171 code. As well would show whether or not o2 sensor response is actually slow, or possible other cause to receive such a code. Just for example.
