RatLabGuy
- May 18, 2005
- Churchville, MD
A question for the engineers here.
I'm working on a project (will probably post pics later) that involves rotating an assembly using a couple of servos. Servo has the typical HDPE wheel on top of the primary gear w/ screw holes.
I'm a little concerned about the stress/torque load on this attachment point, particularly b/c it is fairly small and the holes going through it are fairly small, and I cannot use particularly large diameter screws.
Here is my question:
Which design does a better job of distributing the load across the screw, given that the force is in a rotational direction (around the circle):
- screws in a "plus" style, w/ 2 on each leg, 8 total, or
- 8 screws put in a circle, like an 8-lug wheel hub.
Wobble should not be a problem b/c the assembly is supported by a ring of roller bearings. This is more an issue of the shear between the motor and resistance.
I'm leaning towards #2.
Really this is probably overkill and an academic discussion but hey, it's good for the noggin to think about these things
