rightwinged
- May 7, 2010
- new bern
I have a 86 k5 with 8lug 10bolt front end. Its been having a serious problem lately, that started several months ago. Its well beyond death wobble. The tires wont wobble side to side, but instead top to bottom, as if theres very loose balljoints installed. Bad enough to where my caliper mounting plate will hit my knuckle when i go over a small bump. So to start, checked all steering components, put 4 new balljoints, all new wheel bearings, seals. Jacked it up, absolutely no play side to side or top to bottom. I measured how center the front axle is, and its off by almost an inch. The driver side is almost an inch further foward then the passenger side.So, checked the center pins, both are beautiful and intacked. 1st problem...how is the front axle off that much with the center pins being in great shape? 2nd problem..not sure the offcentered axle would cause that type of wobble.Im out of ideas, and ran out of things to check/replace. Any thoughts would be appreciated.
