Shady (not shadetree) Mechanic
Tacoma747
Winston-Salem
A few months ago I was needing head gaskets put on my Excursion (yes, 6.0 diesel). I had been driving it with them blown for a few months, it ran fine, just built too much pressure in the system (17-20psi). It never really got oil in the coolant, but it did push some out of the reservoir at times. Anyways, I needed headgaskets/studs.
I was referred to a guy up in Madison by Snappy named Jerome, I talked with him a few times on the phone as I am very particular about my Excursion and I HATE paying a mechanic to do anything on it. Local guy near me is a Ford guru (trucks unlimited) that seems to know his stuff, but I just don't really like him (cocky, and gets mad when asked to diagnose a problem but not fix it, to further go into detail on that I got him to scan my Excursion with his snap-on scanner, offered to pay him to scan it, he said no, but gets mad when I want to fix the issue myself--injectors)
Anyways, so Jerome works for himself, low overhead, which makes the price cheaper to repair. He quoted me $3k for the below:
Installation
Taking heads to be checked/machined at machine shop
Headgaskets (ford OEM)
ARP studs
some various little seals and other stuff (which I question if he actually replaced--turbo drain line and such)
Anyways, I SPECIFICALLY told him I wanted the heads taken to a machine shop to be checked for cracks, and machined if need be. He said OK.
My mistake, I didn't get anything in writing before taking him the Excursion...
Anyways, he said 3-day turnaround, I took it on Monday afternoon. He was nice enough to let me come up while the body was off to do some minor stuff to it (I replaced brakelines with SS lines, replaced the radiator with a Mishimoto, and replaced the water pump with a BP Diesel one). All this was done when he was not even working on it, so I wasn't in his way. Anyways, as of Thursday he still hadn't taken the heads off, but said he took them to be machined on Thursday evening and would pick them up from Greensboro (he led me to believe they would be machined at a shop in Greensboro) Friday morning. I went up Friday morning, when I was leaving I called to see if he wanted me to pick them up--he said he was 'there' so he had already picked them up (why drive 30+ minutes to Greensboro and not KNOW they were done?--he didn't actually say he went to Greensboro though). So anyways, I got there, felt like he was lying about having the heads checked, so I took pictures of the heads (they had just been scuffed with a scotch brite wheel, they had NOT been machined). This is where it gets ugly: I asked him again where he took them, he then changed his story and said "A1 Machine in Madison", gave me some long drawn out story about how the guy at A1 had a new machine and he wanted to see it in action... I went out at lunch to go to Orielly's, I stopped by A1 just because I felt he was lying to me, the guy at A1 said he hadn't touched a set of 6.0 heads in 6+ months. I needed to take the Excursion to the beach (left on the following Monday), so I didn't even mention I knew he had lied about this, because honestly, I didn't want him working on it KNOWING I knew he was lying about doing a proper job. He told me Friday it would be done Saturday by 2pm. As of Saturday at 7pm I had not heard from him, so I decided to go up to the shop (granted, it is an hour away from my house), he called me back about 8pm and said it would be Sunday or late that night, I told him to come fix it that evening and I'd take it home Saturday night. He had told me on the phone a couple things that he was held up on, one was he couldn't figure out the Oil cooler lines, but surprise surprise, the oil cooler lines were hooked up properly when he showed up (I was at the shop waiting on him).
Anyways, I helped him finish everything, bleed brakes, body bolts, etc. We got it running about 11pm or so, took it on a test drive, came back, tweaked the exhaust (was rubbing) and buttoned up a couple other things.
Then came the time to pay.... I started videoing with my phone discreetly, got him to write up everything on a bill, then I blew the news that I knew he had lied, of course he denied it. I ended up paying him $2k instead of $3k, I honestly feel I gave him too much and I should not have paid for anything more than just parts, BUT I also feel he is a good mechanic and was just trying to take a shortcut. He had said before he'd offer a 1-year warranty, at that point I knew I wouldn't bring it back to him regardless, he was cussing, coming up with lies to cover himself, etc. He was not happy, nor was I.
I had originally decided not to post this, but after talking with him again today (2+ months after he had done the work) and seeing he is not even willing to try and make it right and fess up to his screw up, I feel it needs to be said. If you take something to him, WATCH HIM LIKE A HAWK. I think he is a good mechanic but will cut corners that should NOT be cut (if these heads are cracked I just wasted $2k, but it might take awhile to show up). Some heads I might agree they might not need to be checked, but NOT a ford 6.0 head.
Anyways, I found a coolant leak today, it was dripping off the backside of the passenger side head so I thought it was the gasket (I had a pressure tester on it and it was dripping pretty bad). I called, he called me back a little later (not knowing it was me), in the time after I first called him to the time he called me back, I found it was actually part of the EGR delete system that was leaking. I tell him on the phone who I was, that I thought the gaskets were leaking but I found he was off the hook (granted, I knew he'd not stand behind his work, but I wanted to give him a chance). He didn't want to hear anything (even when I said he was off the hook), told me I hadn't paid in full so there was no warranty, cussed a few times, and hung up.
ADD ON: Well he just called me again while I have been typing this, said I need to pay the remainder of the bill or he will take me to court (I am not real worried as I never signed any work order, so if he writes one up and signs my name it will be forging my name).
Moral of the story: Get a work order stating ALL work to be done, and most of all, DON'T trust mechanics unless you know them well!
Jerome in Madison, NC. Commonly uses the shop beside Smart Chevrolet (I have nothing bad to say about the shop owner, I never met him, but I have talked with him over the phone)
If you want to watch the videos and see if you agree he was lying feel free: (there are a couple out of order)
https://goo.gl/photos/WZqDYw5zRg5ykobC9
So, maybe I should not have posted this online, yes, I am venting, but, what would YOU have done if you KNEW your mechanic had not done part of the work you asked them to do? I feel like I was more than generous giving him $2k, I even told him I was happy paying $3k (about $2k cheaper than other shops) if he'd have done it properly, but since he hadn't I couldn't bring myself to pay that knowing they might last a year because it was not done properly.
that no work order thing is a double edged sword. bad situation all the way around.
that being said, sometimes people are cocky for a reason. might wanna reconsider that guy you trust next time.
I'll chime in with all I can offer.
Scott (owner of trucks unlimited) has done work for me on 2 vehicles. One had issues. He stood behind it, apologized profusely and offered to let me drive his truck while he repaired it. 3 years later he told a mutual friend that if he ever had problems with the work he'd done for me he'd make it right...
Grade A stand up guy in my book.
He made it right with my friend, kind of... Scott does good work (I suppose), if I wanted to spend $5k + to have head gaskets done I would have taken it to him or Oliver's in Oak Ridge. I have a lift, just don't have a shop big enough to put it. (Who wants a lift in their shop near W-S and will give me keys to the shop?)
I will say that when he was working in my route he was good to go. After that not sure what happened. He has worked on my stuff a few times when he was here
Sorry to hear about your trouble. I would be VERY angry at the guy too. I think it shows his true character that when you caught him in the lie about not having the heads checked and machined, he would not come clean.
It is hard to find honest people to do any kind of work.
In the end, you usually get what you pay for in life.
Yea I took your word for it. I would have never known he hadn't done what he was supposed to have done if I wouldn't have been up there working on it a couple times. Seems to really know what he is doing, but cut corners that shouldn't be cut.
He was supposed to flush/refill the coolant system as well, he didn't do anything other than add a gallon of coolant/water mix (that was IN my excursion) and then topped off with water. I didn't complain about that when it came down to complaining, as it was minor.
I am not sure he actually changed the engine oil, he claims he did but I never saw jugs of oil that night I picked it up, and it was oblver a gallon low (of which I topped it off with oil I had in the excursion).
NOT posting the write up would have been a mistake.
Part of the problem with folks like this is that people are too nice or too worried about hurting someones feelings.
You paid a shit-ton of money for a service that was advertised as being within his capabilities. You specifically asked for certain services to be performed and they were not done to your satisfaction (or at all)
Yes, he might be a great mechanic. This isn't about his wrench-turning, this is about his character and business practices. If he is truly a great mechanic and wants to continue taking on work, he needs to take this story as a serious learning opportunity and do some soul searching to decide if he wants to be great at what he does or just another lying shitbag that happens to know how to work on trucks.
People lie. I hate liars. Period.
I just can get over how you let him talk to you. Calling me an Effing Pussy would have made me lose my mind.
Business is business, but when it goes personal like that, all bets are off.
Again not to de-rail the thread but he quoted me less than $3k for ARP studs and Ford gaskets as well as an EGR delete and oil cooler replacement.
Being in auto repair I'd like to throw in some thoughts.
1: you tell a customer your going to do something, you do it.
2: sometimes the customers don't know best - as the professional it's our job to educate the customer.
3: automotive repairs can't be decided on cost alone. Quality, warranty, customer service and the level of attention to detail.
4: automotive repairs time frame can't be the decider- this job couldnt, shouldn't and wouldn't be done in my shop in 3 days. Maybe I'm slow but I try to pay very close attention to every detail (and work on 50 other things a day)
5: you should have absolutely verified the work when you began to question - and made it extremely clear those heads wouldn't go back on until they'd been surfaced - they can and will leak!
6: $1,000 less than the bill isn't exactly fair, but considering you'll likely get to do it again maybe not extremely unfair. Machine work would run 150-$300.
7: should have never picked it up until you knew it had surfaced heads on it. You have no recourse once you have paid the bill and picked it up.
Hope it works out for you! Even at $3,000 in my opinion you got a good deal!
Dang that is cheap. I honestly didn't even ask him to quote it, but I did get quotes from a couple other shops (both over $5k, and obviously the excursion is a little more involved tgsn a truck). If I had to do it again the ONLY way I would pay someone is if I took the heads to the machine shop myself, and I would still be checking in on a regular basis.
I am just hoping these hold for quite awhile, just the thought of knowing it was done improperly makes me wonder every time I drive it. Even when done properly they give problems sometimes, not worth taking a chance to cut corners in my book.
@mysterync, I felt it would have been a great deal at $3k if done properly. I would have loved to have taken the beads to be surfaced, but by the time I figured it out (friday) there would have been no way it would have been done by the time I needed it (was leaving for the beach on Monday). Plus I didn't want an angry mechanic working on my vehicle after I caught him in a lie. He has still failed to fess up, but you can obviously tell in the video he is lying (plus the fact the machine shop said they didn't do the heads).
I know machine work is not very expensive, which is all the more reason not to skip that step. IF I have to do it over because of that skipped step it will cost me well over that $1k I didn't pay him.
I understand your posistion completely - but taking a truck and expecting this type of repair before a trip with this type of time frame is unrealistic. If you expect to withhold payment on the basis you know he didn't do the job to your specifications, you should have stopped the job at the time this was discovered and discussed it. Failing to do so when it could easily be corrected, yet expect to pay less is a bit of a jerk move. But hey its just opinion.
*After watching the video - it's clear he may be a mechanic but knows nothing about running a business. He could have circumvented all of this by keeping the vehicle until full payment was made, not allowing the customer in the shop, and handling the conversation differently. First thing I would have done is produce machining recipt, possibly pictures of the head and called the associated 3rd parties. Your really going to feel bad if it comes around they were machined! I doubt they were. However the most important and last comment I intend to make here....are other shops seriously charging $110 an hour!?!?!?!? Holy...I need to go up!
May be, but I am not the one that said it would be done in three days. He did. I dropped it on monday, that gave him 2 extra days to have it back to me by Saturday (not counting monday, and counting saturday).
I discussed it with a few people on Friday once I figured out he had not had the heads machined, the people I talked with all agreed they would not want to create a 'agitated' situation with a mechanic that was working on their vehicle. For all I know he could have sat the body on the frame and pushed it out of the garage and said come get it.
Since there was nothing in writing I would have as much recourse on him for not finishing the job (or purposely damaging my vehicle) as he does on me for not paying in full.
Granted, problems come up, but if the heads would have been cracked, I have a spare engine, his main problem with the time frame was not working on it and doing other things instead (I am guilty of that sometimes too, but it is not an excuse). I didn't care he didn't have it done till saturday necessarily, but it would not have been done until who knows when on Sunday if I had not have gone up Saturday evening and MAKE him finish it.
So, jerk move, maybe (I don't see it that way), but would you take your vehicle back to a mechanic that didn't do work they were supposed to do, and won't fess up to skipping those steps? Me either.
I'm not saying your the one in the wrong, just that you handled it the wrong way! This may not mean anything to you - but when I get in a tight spot I always wonder how my pops would handle it. He would have walked in and said "I've never seen surfaced cylinder head, I'd like to take a look at them!" Crisis averted. He would have said " oh they weren't able to do them" or some other bs lie. No issue with pissed mechanic or poorly done job. I guess I just look for alternative options. The first option seem to me like going to the grocery store, picking up a rotten tomatoe, leaving the store without paying, taking it home, cutting it and almost eating it, throwing it away and going back to store and demanding to only pay a portion of the original price?
You know what they say:
Good
Fast
Cheap
...pick any two
Personally, any time a job I'm paying for involves outsourcing/subcontracting/taking to another shop or vendor, I require receipts/evidence from that 3rd party as part of the transaction. I know most guys/places cover subbed-work as part of their own, but that provides to me the evidence it happened as stated.
E.g. in your case, you could have just asked him for his bill of sale from A1.
@RatLabGuy , I did ask for a receipt (it is in one of the video's), he claimed he didn't get one because they 'traded' work. Then he claimed the A1 guy denied doing the work because they had a mutual friend that recently got busted for pot and he was trying to disassociate himself???
I can't agree more. Good shit costs good $.
Likey times a billion!
@mysterync , I did bring it up on Friday, mainly because I saw the heads sitting on the bench and could tell they had only had a scotch brite wheel run across them. He claimed the machine shop checked them for flatness and pressure tested them (this was BEFORE I talked with A1, so although I felt he was lying, I didn't know for sure at this time).
I did say before I took him the excursion I wanted the heads checked, I didn't specify they HAD to be machined (I have talked with a few people that have said scotch brite wheel is 'normal' for good heads that don't need to be machined). He specifically told me they were pressure tested, and checked for flatness. After I verified they were never taken to A1, I brought up this issue in the videos by asking him about the procedure to pressure test the heads, then I asked if he had equipment to do that himself (he said no). This was all BEFORE I told him I knew he didn't take them to A1.
Could I have brought it up on Friday at lunchtime? Sure. Would I have gotten my excursion back in RUNNING condition, your guess is as good as mine. You can tell he was mad in the videos, like a little kid, they don't LIKE getting caught in a lie. The best I could have done is just said "well, I am going to take them to be MACHINED", and pretended I didn't know he never had them checked.
Should I have waited to take it to him the week before going on vacation? Apparently not, but that is beside the point. He said 3 days, he took 5 days and did less than he was being paid to do to boot. I use this on a daily basis (towing/daily driver) so it was hard for me to do without it for even 3 days (I had to make sure I had all my 'stuff' picked up from various places before I could take it to him), I had to borrow a vehicle from a friend while the Excursion was being worked on (that I could not use for towing).
