- Apr 16, 2005
- Sharon, SC
It’s a really nice door. Designed by an engineer that’s a bit short on, well...everything.
Proof of blind squirrels nuts and such
I have never known someone with such focus on a squirrel's testicles.Proof of blind squirrels nuts and such
The purpose is to keep the machine tool corner (lathe, mill, tooling, gauges) more dry. It's nowhere near enough for the whole shop, and probably not that effective, but it makes me feel better. Running a 3 ton AC in an uninsulated shop is a hell of a lot more expensive than a couple hundred watt dehumidifier.If you have access to AC (assuming you fix it), I fail to see any reason to ever use a dehumidifier during the summer.
Its the exact same damn thing, except it dumps all the hot air inside instead of outside, which is the opposite of what you want during summer.
No. I would estimate another 4-6 years before that is complete.Did you fix your door yet?
Just a follow up to this. I'm right on track. Thought about it today though, so another couple of years and it will be done!No. I would estimate another 4-6 years before that is complete.
I could just put them outside so the moisture doesn't even come in!![]()
Container Dri® II Desiccants - Cargo Bag S-14045 - Uline
TYVEK BAG Protects against condensation damage in long distance railroad or cargo shipments. Calcium chloride traps up to 280% of its weight in moisture. Large bags with clip-on hook to hang or suspend in containers, railcars and barges. 5 to 6 bags recommended per 40-ft. container or box and...www.uline.com
5-6 per sea container.![]()
Every week!5-6 per sea container.
So @jeepinmatt would need a couple of dozen or so!
