- Mar 10, 2005
- Hooterville (24171)
Several years ago, I saw a group of 5-6 ton axled truggies bashing up Lower2 and noticed they all had sliders on the front leafs (may have been on the rears, but I didn't notice). They appeared to be custom, as the slots for the bolts/plastic blocks were angled up (front) & down (back) in the channel... not parallel like the AFCO sliders (below) and worked pretty well from what I saw
Pros:
- should snag less than shackles, ends could be tapered/rounded a bit to reduce catching
- should be fairly strong
- should reduce the amount of junk hung off the frame... be it longer than shackles or mounts for reversal = better approach angles?
Cons:
- appear they would offer less lateral movement/bind when twisted up
- could be a PITA to make a set with a slot long enough to work with flexy leafs?
- may not last long (w/o rebuilding regularly) in our dirty environment?
Anyone used them or have experience with them offroad?
I realize this is "archaic", since everyone's gone to links & Coils over leafs. However, I like the simplicity of leafs... since I already have them and ain't considering links anytime soon.
Other opinions?
Pros:
Cons:
Other opinions?
