I've been having a lot of problems lately w/ Phoenix feeds not working.If your gonna cut the cord
Fire stick with kodi and install exodus and phoenix
I am cutting the cord this month after I get 1 more fire stick for the bedroom tv
anybody else?
For us a big issue is local main networks. We have an antenna, I've tried everything and we just can't get CBS reliably and NBC is hit and miss.
Mentioned this in the other thread. I actually do now have 2 antennas just for that reason. We mostly get 11 but 13 is a crapshoot at best.You're using a UHF antenna. You need a VHF antenna to get BAL and JZ. (11 and 13, respectively). WMAR is nominally channel 2, but broadcasts in the UHF band since the digital switch.
All three networks are on the same tower, and 54 is right next door, so if you can get one, you should be able to get them all. PBS will be just a few degrees to the left. You should be able to pull in all the DC affiliates, but you'll need a high-gain antenna and maybe an amp.
