marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
Hi everyone, got the weed eater out to start the season and the stupid little fuel pump thingy won't pump fuel into the carb or anything (won't fill up with fuel like it should) therefor it won't run...after 10 pumps it will start but die cause it won't fill up with fuel. I checked all the lines by unplugging them and checking for leaks by blowing through them, all good. Filter in the tank all good.
I'm ok with these things but loose patience very quickly working on these small engines.
Any help/ideas that I'm missing would be very much appreciated, thank you!
I'm ok with these things but loose patience very quickly working on these small engines. Any help/ideas that I'm missing would be very much appreciated, thank you!
