please ignore the ugly piece of tread plate I used to stiffen firewall for brake booster as I said this was supposed to be a quick 2 week fix that turned into a nightmare as you will soon see...
ok so on to the next pic filled update.....
so here we go...firewall after i removed battery tray...
battery tray...lol
after initial grinding/sanding...
the black line represents approx where the first wo holes will be drilled...the darkish circle is come wierd indentation/outgrowth im guessing they used to take the tincan sound out of firewall(i.e. tighten up the sheetmetal)....
i didnt like how the firewall flexed when i put pressure on it so after cutting out the wierd section i plated a large area of it with 1/8" diamond plate..just some scrap i had laying around so its not super pretty but net end result was great...
weirdness removed...:hahaha:
diamond plating...
after some hole sawing and drilling...
test fit...like a glove baby...like a glove...
inside after removing existing accelerator linkage mounts...(that was a mistake)
pedal assembly...was going to use the gas pedal as well but realized how much extra work/crap to find etc that was going to cause...reason for this is brake pedal was going to hit original accelerator linkage...
after removing gas pedal...
modifying original linkage...
test function/fit after welding mounts back in...lol....
clears brake pedal and works nicely...
clearance and ease of servicability in relation to factory fender with no trimming...
linkage after a coat of paint and i changed out the pedal pad area as well for the matching pedal and pad to brake pedal
rim and a 225/70/r15 on with full weight on springs...i think a set of 30-31" tires will be perfect....
well thats it for pics today...ordered a set of 15" factory 99 wrangler rims off of ebay today...will paint em up good when they get here on the hunt for tires now.....also did a little research on converting the A727 transmission to 4wd...seems all i got to do is change out the tailshaft and adaptor...then get a dana 300 and a clocking ring....well im out cheers:cheers:
