kaiser715
Doing hard time
- Jun 1, 2006
- 7, Pocket, NC
With the new house build, I have been planning to put in a standby generator.
Original plan, up until today, was to put in a small one -- 7.5kw -- just to power the most essential circuits (using their 8 slot subpanel style transfer switch). Fridge, freezer, alarm, video, septic pump/alarm as the highest priority items. Then I was going to do a manual connect and switch for my big Diesel genset, that would pretty much run everything as needed.
After talking with the electrician, I am thinking about changing up....basically the time cost, etc of installing the 8-circuit panel (and disconnect/interlock for the diesel), vs a service entrance rated ATS (200amps) for the whole house.
Thoughts right now are a 20-22kw that would run my heat pump (2 stage, 4ton) and most everything as needed (but obviously, not all at one time). (Would lock out the 15k resistance aux heat strips when under generator power).
Biggest downside I see is increased fuel consumption -- 1gph vs 2gph of LP at half load.
Cost is a wash because I would sell the Diesel.
Thoughts?
Thoughts?
. I hope the fuel truck can run during extended outages!
