Stripped TH-400 tailhousing holes?
Caver Dave
Just holdin' it down here in BFV
Moderator
Hooterville (24171)
If you missed it here, all the bolts that hold the AA adapter to the arse end of the TH-400 pulled the threads this weekend at URE.
Wasn't on it or anything, just rolling thru a nuisance trail to another place, when the sounds started... shut it down and found everything from the adapter back hanging by the mount...
Soliciting info on "best" repair short of a Reid case (if an AMC-belled TH-400 was even an option, likely out of the budget)
- Helicoil? My "best available data" (BAD) info says helicoiled will be stronger that the originals?
- Other stake able insert? But not sure the castings would take the radial force of the stakes?
- Punch the holes out, thread 7/16", and glue in some studs?
Measure how much meat you have
Tina Fey Silence GIF
Haha.
Well, I deserved that one, lol
The best campfire drinking song
I used to work in West Virginia in an old department store, I used to work in West Virginia I did but I don’t anymore.
A woman came in for some meat, some meat she wanted, my sausage she got.
There's helicoils, twinserts, slimserts, and keenserts.
A helicoil would require removing the least amount of material.
A twinsert is a helicoil inside of a helicoil.
A slimsert is a threaded insert that screws in and gets flared out at the top. The OD of the flared area is splined.
A keensert has 4 stakes that hold it in place.
I'd probably do a helicoil and if that ever failed, I'd go right to a keensert.
TBH I would buy a new adapter unless I could just through bolt it.
The AA adapter appears fine... the 6 bolts thru the adapter into the TH-400 case are what stripped.
After a few kind clues from several local/distant builders and racers... it appears that drilling/tapping to 7/16" right outta the gate during the build should've been in order? Meaning its typically done before 1st use as a means to negate the current state...
Look up timeserts. I use them all the time in situations where parts can't easily be replaced. If you drill and tap them bigger, fine thread may be a good option.
