Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
Yet another of my strange questions about best-practices for building stuff....
Bathroom fan ducts exiting house wall to wall caps, two of them next to each other (for two different bathrooms).
There will be a mounting block for the wall caps, and the wall caps slide into the rigid duct. The rigid duct will be supported at the mounting block. The rigid duct will be fairly short (through the 2x6 stud wall, and then coupling length), and then a piece of flex duct will connect from there to the inline fan.
So: How do I support the other end of the rigid duct where it exits the wall on the interior side? I want to do 2 points of support, so the exterior wall block would be one point, and I want another point. Basically I don't want to only support the duct at the wall cap side, and have to worry about breaking the sealant because of relative motion if the flex ducts needs to be serviced or reattached.
Should I just make a plywood/OSB plate that spans across 2 studs and has a hole for each duct?
Less important background info:
Cosmetics aren't important; I'm making a shallow mechanical space behind the back of a linen closet. I'm assuming the finished back of the closet will satisfy the vapor barrier requirements, etc., and the insulation will be in the exterior wall studs per normal practice. Both fans will be in the mechanical space.
The duct runs will be really short, as one bathroom shares a wall with the closet (cathedral ceiling from the first floor) and the closet is inside the other bathroom. Maybe 5-6 feet total duct length from each shower to the wall caps, including the inline fans.
I could actually make the ducts all or mostly rigid, but I know the flex duct would be quieter (but slightly more flow restriction). Could use rigid and put a flex coupler between the shower and fan also...
Going with mostly rigid seems like a pain in the ass to couple together with such short duct runs...
The fans aren't in or above the shower enclosure, so happily no requirement for GFCI protection.
