gmcjimmy88
Active Member
- May 15, 2005
- Fayetteville
Ok I pulled the fuse box and all from my 90 Blazer to use in the 86 Blurban. I figured the easiest way to do it the swap would be to run 2 seperate fuse boxes. Use the original 86 wiring for the starter and charging system as well as the rest of the truck. I figured I would use the 90 TBI to operate the ignition and the TBI. I figured I would run a hot from the run position to the 90 box to get is power. I will have to ensure that this wire has power during the start position as well.
Any ideas on what wire to get feed from on my 86 fuse panel?
I still need to find a fuel pump if anyone has one laying around?
What is the bare minimum needed to run the TBI setup?
How do I mount the 90 fuse panel? I was thinking of mounting it to the inner fender well inside of some kind of sealed box? Will it get to hot?
Any help would be great since time is getting short before the URE trip in mid August.
Course most times you get what you pay for, maybe it's worth the money seeing as how my $66 E8153, brand new, crapped out in 2 weeks of testing on the engine stand
