Just a FYI if you don't already know. You have to use a ecm out of a 94-95 truck or least find one from a grand Cherokee with out an alarm. When I did my swap into my cj it would start with the ecm from Cherokee but most grand Cherokee came with an alarm system and will shut motor back off few seconds later. On obd1 ecm no way to disable this alarm best I could figure out.
Also truck ecm looks for 2 o2 sensors one on each side for dual exhaust. The Cherokee uses a single o2 cause has single exhaust pipe. If you do run dual exhaust with Cherokee harness which only uses 1 o2 make sure you install o2 on driver side. Will cause problems in stock location on passenger side with dual exhaust and single o2. Long as it is on driver side truck ecm seems to work fine even with only 1 o2. I learned this the hardway. Hope that's not to confusing.
