TJ 2.5 to 4.0 swap???
Rox&Mud
CTB
Rocky Mount
I'm looking at swapping a 4.0 into a TJ that had a 2.5l. I know the motor mounts will need to be moved. What I need to know is does someone make a kit for this or do you have to cut off the original mounts and move them? I've done some searching and everything I find is to swap to a bigger GM or Chrysler motor.
I'm planning on using a donor jeep so all the drivetrain/wiring/computer etc will be availiable. My main concern is moving the engine mounts. Most of the threads I've found don't get into the mounts too much, I'll check the links posted and see what I can glean from them.
I know a few of them do get into moving them.
heres a tip on how I have learned to search for info on forums
Goto Google and in the search line enter:
(what you looking for) Site:NC4x4.com or Site:pirate4x4.com
For example -
2.5 to 4.0 swaps site:pirate4x4.com
You will get allot better results than searching on the forum. All the results will be from just the site you listed.
I know its helped me when researching
