TJ axle swap
SPOA87YJ
Charlotte
Anyone have interest in performing the below work on a TJ?
1) Install front D30 - will need brakes swapped onto the new axle and then installed.
2) Install rear D44. Axle has truss for triangulated uppers already installed (was removed from a TJ with stock wheelbase) Will need upper control arms built with frame mounts once the axle is located under the jeep.
3) Install 1" Motor mount lift and 1" Body lift to allow Undercover fab skidplate to be installed.
I've gathered the parts but just don't have the time right now. My goal would be to have the work complete by the end of August.
Thanks in advance,
-Austin
