Joey De La Gwyn
- Aug 22, 2017
- Liberty
I think I know the answer but not 100% sure. I run a 4" lift on stock arms now. Could I run 6" springs on stock arms till I can get longer ones?
@Jason W. just needed a point of start with maybe a length.
Thanks @CasterTroy big help. And at this point @tlucier I'm not sure about using the 6" springs but thinking of just building my own long arms and keeping the 4" lift I have now
Very true, with only ~2" I could fit 37s on mine right now if I trimmed the rear corners some.You can put a whole lot of tire under a tj with 4" springs, depending on if you got the other hardware to back it up.
You're missing a lug nut. And four coil springs and ten links.
