Hull one of our new 35. Absolute battle wagon offshore today.Show special or you hauling it back for the factory? Either way, beautiful spec.
I might have to try out some tunes from the people that did yours. My 2012 is deleted on 35's and my liometer is typically saying between 8.5 and 9.8 and hand calculations usually average around 8. I never drive it empty so no idea how it does without a load, I'm usually grossing around 17k behind the truck, no idea what the truck itself weighs. I know that I traverse more elevation leaving my driveway than you could driving through 3 counties down your way and that makes a difference, but I would love a serious mileage increase if possible.First trip on the hwy. Lieometer is at 21mpg and cruise is set at 78 for a full tank, filled up and hand calculated a little more than 16mph...
But it's got lots of power and at that speed with 35's it's at 1950 rpm. Trans tune seems happier, truck feels like it's in the right gear all the time now and she pulls better.
Before the delete I was getting 15 on the lieometer so who knows what I was actually getting.
Anyway had to go fetch this rig out of downtown South Beach Miami this morning (absolute Mayhem getting there and worse leaving with it loaded). Splashed it at a local boat ramp and ran the boat north for more testing. But the truck pulled great. That little skiff weighs 18,500...View attachment 433847
Dang. My 5.9 gets 12 loaded. But I don’t kill it. Unloaded 16-20 speed is a very big factor in my mileage. I can cut a tank in half almost by running 80/85 instead of 70/75. Notice it a lot hauling camper to beachAt 17k behind the truck I doubt you see any serious increase, although when you're in the single digits any increase helps. I average between 7 and 8 towing my dump trailer, total scale weight is just under 18k empty and usually between 23k and 26k loaded. It's also a 10ft tall brick so that doesn't help. Empty I can get north of 16 on the highway, closer to 14 in my normal mixed driving. I do have some new tunes to put in though when I can get back in the garage.
Duane
Towed my boat home yesterday from Lauderdale. She's 10'9" wide and was grossing a touch over 28k. Averaged 8ish mpg at 68 mph in 5th which was 2150 rpm. 70-72 mph the drone set in pretty good. In 5th at 68 engine load was mid 20% on the ezlynk. Tried 6th gear at 72mph engine load went up to 30% mileage was the same rpm dropped to 1780 ish and boost was 13psi in either gear. Egt's we're 950 in 5th and touching 1000 in 6th. Truck felt fine either way, but don't think I should tow that sort of weight in 6th???
Only white knuckle was 95 in Lumberton through Fayetteville construction with narrower lanes.
Diff temp got to 230 deg at the hottest. Running straight gear oil so I'm getting some limited slip clutch chatter, but that's fine with me.
Very satisfied with 4.10's
Pretty much what I do as well. But I did try 6th to try and reduce the drone with higher speed. It worked and held 6th fine (i95 is flat) but I couldn't stand the thought of that 6th gear holding that torqueFWIW, when I'm loaded that heavy I usually just leave the stick in manual and don't use 6th. Its quick to downshift into 5th with that weight even with the Aisin.
I do the same with my 2012 5.7 w/3.73s or else the 66RFE drops down out of 6th all the time. Same ratios as the 68RFE. Tows fine that way.FWIW, when I'm loaded that heavy I usually just leave the stick in manual and don't use 6th. Its quick to downshift into 5th with that weight even with the Aisin.
