EdJonesJeeper
The Stig's NC cousin
- Apr 24, 2010
- Pisgah Forest, NC
Replaced the coil yet?
So 4k RPM under load only...?
How do I check the coil?
It's the best kind of Toyota, a paid off one.Trade it. Make it someone else's problem. Easy for me to say as I'd never own a yota anyway. Just my .02
Good luck with it Josh. You got a baby yet?
RCan I do the told you so dance?Check the maf.
Usually I'm never a fan of blindly throwing parts at something to see what fixes it, but when it comes to ignition coils there aren't many diagnostics that you can do. The only easy things you can check are things that would affect the coil all the time, like shorted insulation or something like that. If you're talking about something that's temperature dependent, or RPM dependent, etc., there isn't much you can do besides replacing it and seeing what happens. High voltage is really nothing you should mess with, so when the engine is running then leave the coil alone. Camrys have fairly common coil problems, and Avalons share a lot of the same parts, which is the reason I'm suggesting the coil as a possible suspect
